Lost roughly 300 points on Timespy cpu score?
scgt1
So I was benching my new 2070 with Timespy on the 17th. I've had windows update since then and I'm just now getting around to attempting more over the scanner overclock.
Might I say they did a good job with that because if I bump the core up to the next notch it crashes Timespy. lol
Anyway I had some windows updates this morning and I'm wondering if they put patches in for this new Zombieload or what ever it is that may be affecting my scores on my 6700K?
When I was benching on the 17th the cpu scores were pretty level +- a few points but to drop around 300 points seems a bit odd to me. Not running the cpu overclock so nothing has been changed with it just the windows update that ran this morning is the only change.
More Spectre / Spectre-NG mitigations??
Mother F! Looks that way.
May 14, 2019—KB4494441 (OS Build 17763.503)
  • Enables “Retpoline” by default if Spectre Variant 2 (CVE-2017-5715) is enabled. Make sure previous OS protections against the Spectre Variant 2 vulnerability are enabled using the registry settings described in the Windows Client and Windows Server articles. (These registry settings are enabled by default for Windows Client OS editions, but disabled by default for Windows Server OS editions). For more information about “Retpoline”, see Mitigating Spectre variant 2 with Retpoline on Windows.
  • Provides protections against a new subclass of speculative execution side-channel vulnerabilities, known as Microarchitectural Data Sampling, for 64-Bit (x64) versions of Windows (CVE-2019-11091, CVE-2018-12126, CVE-2018-12127, CVE-2018-12130). Use the registry settings as described in the Windows Client and Windows Server articles. (These registry settings are enabled by default for Windows Client OS editions and Windows Server OS editions).
