Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I believe if you set your camera to PC Connection in the menu (it's usually set to Print/PTP and the menu is the last one menu tab) and plug it into your laptop it should charge it. Might want to look it up but I swear the indicator stated I had half battery and I decided to hook it up to my laptop to do some shots over 2-3 days. I took about 200+ pictures while it was hooked up with my laptop. Now the indicator stated the battery was full. Even after 200+ pictures I don't see how it wouldn't be half way at that point if the battery was full to begin with. Oh and I am using a Rebel XT. Try to ask around first I am not 100% certain.
