Lost antec tpq-850 modular cables
SePhIrOtX
Hi I bought an used Antec quattro 850 power supply and the guy lost his pci e cables. From antec I cant get them since its discontinued. Can I use another modular cables and if yes, wheres can I get them. I'm from Canada
If the cables are the same as the 1200 watt unit I have some brand new spares at home if you can't source them anywhere else.
If they use regular connectors, you can buy the connectors and try to wire it up yourself. You'll need a multimeter to measure the voltage of each pin so that you don't put 12v on ground and vice versa.
Thanks for the reply. I just found someone who got an extra set. This thread can be closed.
