Sep 26, 2008 #1 J jman888 n00b Joined Jun 12, 2007 Messages 40 Help me Plz, I lost the Admin Account Pasword for my Vista PC and can only get on my sisters (Non Passworded) Account. How can i recover it please
Sep 26, 2008 #2 S Sparkyy [H]ard|Gawd Joined Mar 16, 2006 Messages 1,166 You might be able to reset the password with a program called, Passware: http://www.lostpassword.com/ Other then that program I can only say reformat?
Sep 26, 2008 #3 C criccio Fully Equipped 2FA Joined Mar 26, 2008 Messages 14,688 You can change it with ERD Commander,
Sep 26, 2008 #4 C ChingChang Supreme [H]ardness Joined Mar 27, 2003 Messages 6,504 http://www.pcloginnow.com/
Sep 26, 2008 #5 J jman888 n00b Joined Jun 12, 2007 Messages 40 Thank you the pclongin. this is the only thing i could make work.
Sep 27, 2008 #6 T TechieSooner Supreme [H]ardness Joined Nov 7, 2007 Messages 7,601 jman888 said: Thank you the pclongin. this is the only thing i could make work. Click to expand... Does this just reset it or tell you what it is? OPHCrack is my tool of choice- but this tool actually decrypts the darn thing, which IMO more than likely takes longer than resetting it.
Sep 27, 2008 #7 C ChingChang Supreme [H]ardness Joined Mar 27, 2003 Messages 6,504 pcloginnow just resets it. also allows you enable/disable accounts including administrator and guest. best free password reset program I've used. better than some of the paid for ones
Sep 28, 2008 #8 V Vague Limp Gawd Joined Apr 17, 2008 Messages 253 I have a sysinternals disc from work that I use. It's 3 or 4 years old but works with Vista.
Sep 29, 2008 #9 R Rampage1329 [H]ard|Gawd Joined Dec 5, 2006 Messages 1,774 ntpassword reset. Really couldn't ask for anything else, it makes it a joke.
