Loose Molex
zenius
Does anyone have any techniques/ideas how to prevent molex plugs from coming loose. The fans that came with my Antec P182 are all molex and it's a real bother when the molex connectors get loose. They're plugged in but it always happens that the connection comes lose and the fans go off.
Those must be some bad quality fans...
Electrical tape? :rolleyes:
What's coming loose, the connection between two connectors, or the metal pins from the connector?
i believe it's the pins 'cause the plastic parts of the molex connectors are in place
Cheap Chinese molded plastic, hack off the plug and replace it, I have run across this problem a few times in the past.
