Loose IDE hdd cable
lessthanjakejohn
THe ide cable wont stick in the hdd. any ideas for a quick fix? I can hold the cable in, but when I let go, the computer loses the connection. What do i do short of buying a new cable?
tape? i dunno...never had that problem
id say just buy a new cable...they're pretty cheap
get new IDE cable, or use electrical tape to tape it on.
best bet: new cable before you break your drive or computer with it going in and out while turned on. doubt your motherboard supports hot swapping... so dont try it...
Originally posted by lessthanjakejohn
I fucked with it some more and now it seems to be broke or I fucked over my HD, which I doubt...
clear your cmos... if that doesn't fix it, it's the ide cable or HD :p probably the cable
