Loop Question
W.Feather
[H]ard DCOTM x4 & [H]DCOTY x1
Working on putting my loop back together, looking for suggestions/answers to my questions :D
1) I have monsoon compression fittings, they have two sets of o-rings in the packaging, why? I have only used barbs peviously so i dont know what to do with the 2nd set (I put one of em on the bottom of the barb lol, didnt seem to harm the compression at all, should I remove it? )
2) Trying to figure out the best loop setup, I dont think it will take much of an difference and going for the easy way would be smartest, the rad is an RX 360 with 6x AP-15's on it.....I have the XSPC Rasa CPU block, 2x Alpha Cool 6970 blocks (in parallel, see picture), and the block on my board.
Thinking of doing: Pump/Res -> CPU -> GPU -> Board -> Rad -> Pump/Res ... thoughts? Looking for quick thoughts if possible:D
Thanks,
-W.Feather
Edit: Forgot to add the loop/board as it stands :D
[IMG=http://img5.imageshack.us/img5/8383/20130308221933.jpg][/IMG]
Uploaded with ImageShack.us
You would be correct, loop order doesn't really matter and just configure it the easiest way you can.
You should only use one o-ring at a time. Two might create some unforeseen complications, like gaps between the rubbers, etc.
Ya i see, got it running a leak test now
IT is a PITA to fit everything in an Antec 1200....not a very friendly case for this i must say ... cant wait for a new case later this summer......had to moutn the rad and half the res/pump external lol :D nothing some [H] modding wont fix
