Loop question.
Pitbull
Right now i have a 120.2 rad, 655 pump, and a block on a CPU. The pump sits at the bottom with a t-line right there, my Rosewill Thor V2 is coming tomorrow and i'm planning to have the rad up top instead vertical outside of the dual 120mm fan slots on the back of the current crap nzxt zero case. Where would be the best place to put the t-line now? or should i just get a reservoir to make this simpler?
You could still use a T-line. The best place for it would be before the pump inlet port. A reservoir does make things easier in my opinion, so do whichever you want.
