Loop order advice
Gorilla
Here is a quick look at how I am planning my loop. Any thoughts or suggestions? And yes, I am aware that 7x120mm is way overkill, but isn't that what [H] is all about. My only real concern is ventilation. I cut the side panel mesh out of my side panel and installed a full window so air can no longer exit there. There are still vents on the bottom and rear.
Looks good. I would think about flipping the top from pulling into the case to blowing out
Loop order doesn't matter, just route whatever way is easiest.
