I have a SeaSonic 600W PSU that I am going to loom up. I have the kit but I don't have the tool that removes the molex connectors.
This is what came in my kit:
* 10ft- ⅛" sleeving
* 10ft- ¼" sleeving
* 5ft- ⅜" sleeving
* 5ft- ½" sleeving
* 12x zip ties
* 1ft- 9mm Heatshrink Tubing
* 1ft- 18mm Heatshrink Tubing
* 6in- 24mm Heatshrink Tubing
Now my question is. What's better to do, cut the connector (dumb idea I know), solder and heatshrink every wire back on with another larger heatshrink tube to secure all the wires or get the molex remover and do it that way.
What would you do?
* 10ft- ⅛" sleeving
* 10ft- ¼" sleeving
* 5ft- ⅜" sleeving
* 5ft- ½" sleeving
* 12x zip ties
What would you do?
