Looks like 3Ghz is it
cditty
Well, I've tweaked my E6600 and I can't get over 3 Ghz prime stable. On the positive side, 3 Ghz was all I was hoping for and I can run at 1.38 volts. My load temps (dual prime) are only 43-44C with a Zalman 9500LED. So, I guess I'm pretty happy with the chip. It is definitely fast.
Chris
I'd feed it up to 1.45V and see how far it goes. Past 1.45V, and you're starting to push past "okay" voltages.
1.45v is all I'm willing to give my E6600 too (on a DS3). I have air cooling and I'm sitting @ 3.2GHz (356x9) - any higher and the temps are too high.
Chris
I would be very happy if you would post all of your info in the Conroe Overclock Database thread.
You too soki. Please? ;) Soki nevermind I found your info in my thread. I never put it in the
database because you never came back to tell me if it was stable. It is in the database now.
Your memory is at 712MHz correct? 356x2=712.
yeah that's right, 712mhz for memory. The last time I ran orthos overnight on this setup, it worked but I forgot to take a screenshot.. I'll get that for you soon.
other info:
E6600 OEM (not ES), L625, 6 B2 stepping, code is A209
Scythe Ninja Plus (air)
CPU watts: default (65 I guess)
Vcore: 1.45v
motherboard: Gigabyte GA-965P-DS3 (F4 BIOS)
RAM brand: CORSAIR XMS2 DDR2-800 (PC6400) 5-5-5-12 (I manually set these timings in my BIOS now so I know they're right)
Got my E6300 and its running very stable (dual prime 14hrs) @ 3.3ghz (472 x 7) stock voltages and heatsink. :D
I want to push more but I'm waiting til I get liquid cooling.
other info:
Vcore: 1.45v
RAM brand: CORSAIR XMS2 DDR2800 (PC6400) 5-5-5-12 (I manually set these timings in my BIOS now so I know they're right)
Cool, look for another update in the Database thread tonight, you are on it.
I'm gonna ride it out at 3.0 @ 1.38 volts. It's a good oc and I don't want to risk a $360 chip for another 100 Mhz @ 1.45 or 1.5 volts. It already makes a big difference encoding audio, video, etc...
Chris
gepetto said:
looks like i beat you and saved myself $200. sucks to be u.
It's nice to see the highly mature nature of some of the forum posters. :rolleyes:
(cf)Eclipse said:
i'll warn you, maintaining the database for >3-4 months gets to be tiresome and boring :p
Oh boy prepare to be shocked and amazed.:D
My first 3DMark05 list post.
See the date on that? October 2004. I have only been here since September 17th 2004.
I still update the 3DMark05 list about every 20-25 new entries. The next update will
contain at least 1,700 scores.
In fact I promised to update that 3DMark05 list unitl I die. Or until I don't get any more
submissions. Or until the thread is locked and I am told not make another one.
I plan on updating this Conroe list for quite some time. Probably over 2 years. :eek:
My secret... I am crazy insane for data and for lists.
EDIT
Hey! I am nearing the 2 year anniversary for the 3DMark05 list. I will have to do something
special to celebrate.
