Looking to Upgrade, seeking advice.
MasterMike
So I built this new computer a few weeks ago with the following specs:
ASUS P5GDC-V Deluxe Motherboard (DDR (4) and DDR-2 (2) RAM Slots)
P4 3.0GHz HT
nVidia GeForce 6600 256MB PCI-e
1024 PC3200 DDR SDRAM (Two 256MB sticks and one 512MB stick)
Sound Blaster Audigy 2 Value
I ran the 3dMark 05 and my computer clocked in at a 3DMark Score of 2100. It was quite depressing to watch the video scenes at a mere 8-12 FPS. I've already put a reasonable amount of cash into this computer, so I'm trying to remedy this issue as low cost as possible. I seek advice on the following question: What do you recommend I purchase to bring this computer up to speed? Should I upgrade the video card (maybe a 7800GT)? Or does my RAM need fixing? A friend of mine speculated that the odd configuration of RAM I have may be the cause of this problem. If I do go the RAM way, should I purchase:
CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory - Retail $235.00 (Mail-In rebate of $28.00 makes it $207.00)
-or-
CORSAIR XMS2 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 675 (PC2 5400) Dual Channel Kit System Memory - Retail $255.00
I haven't considered video card options at the moment since the RAM seems to be what I'm heading towards. Just looking for input on the issue, any help or advice is greatly appreciated. Thanks.
those low fps are normal in 3dmark.. it's not meant to be playable, and that score is around typical for a 6600. memory isn't gonna help it out much ;)
Even so, I've noticed decreased performance in many games, most recently F.E.A.R.
Does the current RAM setup I have create and issue, and would an upgrade of this sort provide a good chunk of performance increase? I don't care as much about the 3DMark score as I care about overall performance. Also, during a test with overclocking, I was able to get it up to a stable 26FPS, but I heard things about overclocking = bad, so I didn't stay with that.
depends.. does the bios say it's in single channel or dual channel when the computer is booting?
