Jan 14, 2006 #1 T ThR!LL Limp Gawd Joined Jan 9, 2006 Messages 342 Ok I'm looking for a good heatsink that isnt huge and will fit on an Asus A8V without getting in the way of the RAM. Any Ideas?
Jan 14, 2006 #2 T ThR!LL Limp Gawd Joined Jan 9, 2006 Messages 342 my proccessor is AMD 3700+ San Diego
Jan 14, 2006 #3 K _Korruption_ Supreme [H]ardness Joined Aug 22, 2002 Messages 4,572 Don't miss the sticky...
Jan 14, 2006 #4 T ThR!LL Limp Gawd Joined Jan 9, 2006 Messages 342 I was looking at it but I don't know if it an xp-90 or any other 90mm thing will fit on my mobo because there is basically no room on it. Heres a pic http://www.newegg.com/Product/Product.asp?Item=N82E16813131541
Jan 14, 2006 #5 K _Korruption_ Supreme [H]ardness Joined Aug 22, 2002 Messages 4,572 http://www.thermalright.com/a_page/main_support_faq_motherboard_xp90.htm What makes you think the XP-90 won't fit? It is compatible with nearly every board out there.
Jan 14, 2006 #6 T ThR!LL Limp Gawd Joined Jan 9, 2006 Messages 342 i measured the space between the heatsink to my closet slot of ram to it and it was about 1/2 an inch.
Jan 15, 2006 #7 K _Korruption_ Supreme [H]ardness Joined Aug 22, 2002 Messages 4,572 You measured, but Thermalright knows it'll fit. I think I trust Thermalright more. Besides, you don't have to have the XP-90 overhanging the DIMM slots. I'd have it hanging over the voltage regulators. It will fit.
Jan 16, 2006 #8 T ThR!LL Limp Gawd Joined Jan 9, 2006 Messages 342 K Thank You I just needed some confirmation before I bought a heatsink.
