There's a reason the Westy worked so well, it's because it was built to be a monitor first and foremost, and it's firmware was programmed for that function.They don't make a TV that your going to be happy with, the Westy was a special case, no other TV's look like it.
Hoping you can post your 37LK450 results for us once you're done with the cable swap and tweaking. Going by the hundreds of posts i've read on that model, i would think it would be more than an incremental improvement. I do wonder how much of a difference the 32" size would have made for you, with it's smaller/tighter picture and all, too bad the 32" LG IPS panels are nearly impossible to find....I just replaced my Westy with a 37LK450; mine was starting to exhibit the random power-off issue. So far, its merely OK, given that I am still using an HDMI-to-HDMI connection and thus not getting 4:4:4 yet. It took a lot of tweaking but I was terribly disappointed by the out of the box experience, and I still haven't taken the wrap off and thrown away the packing material of the 37LK450. With a large amount of tweaking, it is acceptable, I guess. I should have the DVI-to-HDMI cable/adapters tomorrow and that will tell the tale.
