I've been using this eSATA RAID card (based on the Silicon Image 3124 chipset) for a while but now I want to upgrade to something a little better. This card only allows me to create a RAID5 volume with a maximum of 5 drives and it employs software RAID5. I want to be able to create RAID5 volumes with 8+ drives and would prefer a PCIe hardware RAID5 solution. I need at least 2 eSATA ports with Port Multiplying. I'll be using this card along with a Proavio editBOX 8PM. I'm looking for some suggestions from you guys outlining which options I have. I don't have a set budget but I realise it may be quite expensive. The card the manufacturers offer when buying this enclosure is the Highpoint RocketRAID 2314.
Thanks in advance for any advice.
