So, I've learned a few things over the years building a comp. Don't compromise on the PSU, don't compromise on the monitor and now don't compromise on the case. Sure, it's pretty quiet, but if I OC and stress test the temps just keep climing.
That being said, I am looking for a case that is both quiet and runs cooler. It doesn't have to be loaded with sound dampening material, since I think you can achieve 95% of that just by using quiet fans and equipment.
Budget is not too much of a concern. I'd like to stay under $300, but that seems easy enough to do. My search keeps leading me back to the Silverstone FT02. Is there anything else comparable to the acoustics plus cooling combination of this case? I want to make sure I'm not missing out on other cases. As a side note, the Thermaltake level 10 GT is out due to personal preference.
I've found a lot that acoustically are similar to the FT02 [R3, P280, 550D, etc] but don't seem to keep up with the cooling. Granted they also cost quite a bit less.
