Looking to replace 14" case fans - Recommendations?
hp9000
Hi,
I want to replace the cheapo 14" fans that came with my case. They make too much noise. So I'd like to know what you recommend both in terms of volume of air pushed and noise levels. I know that some fans come with unusual blade shapes, or speeds, etc.
Thanks a lot!
14 inches? Do you mean 140mm? There is no such thing as a 14inch case fan (355mm)
What case do you have?
Xbit Labs has a great roundup on 140mm fans. I can't link it at the moment cause the site is not responding for me. Google it and you'll see it.
