Looking to do an upgrade, need some advice
CalsonicGTR
I'd like to downsize my current computer, and get more powerful at the same time. My current rig:
C2D E6750 @ 3.2, Abit IP35 Pro, 4GB XMS2, HD4890, Corsair HX520, etc...
1) What will you be doing with this PC?
Mostly normal use, some gaming (Steam games)
I'm looking at a budget around $4 - $500 dollars
US, Illinois
CPU, RAM, Motherboard, Case, HSF (if necessary)
Corsair HX520 PSU
Sapphire Radeon HD4890 Video Card
Western Digital Black 750GB Hard Drive
SATA DVD Burner
6) Will you be overclocking?
I'd like to do a little overclocking, not going to go very extreme
20" Monitor(1680x1050), TV (1080p)
Whenever, not in a rush
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0, decent onboard sound, must be mATX (case and motherboard)
Yes, Windows 7 Pro x64
I was thinking something along the lines of a 2500K, but thats really as far as I got. What else would you guys recommend? Will the stock Intel cooler be enough for some light overclocking? Should I look into a new PSU as well?
Well if you plan to order this week, then go with this build. Otherwise, bump this topic the week you plan to buy.
$219.99 - 2500k
$89.99 - MSI P67S-C43 (B3) LGA 1155
$29.99 - COOLER MASTER Hyper 212 Plus
$47.99 - G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
Total: $387.96 plus shipping
Choose your own case, I recommend the following:
$60 - NZXT Source 210 Elite ATX Case
$60 - Cooler Master HAF 912 RC-912-KKN1 ATX Case
$70 - Lian Li Lancool PC-K58W ATX Case
$70 - Lian Li Lancool PC-K56 ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$100 - Lian Li PC-7FN ATX Case
$110 - Lian Li PC-60FN ATX Case
$113 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$110 - Fractal Design Arc Mini Tower
$120 - Corsair Carbide Series 400R ATX Case
$130 - Fractal Design Define R3 Black ATX Case
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$140 - Lian Li PC-9F ATX Case
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$140 - Antec Performance One Series P183 V3 ATX Case
$143 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
$150 - Corsair Graphite Series 600T ATX Case
$160 - Silverstone RV02B-W ATX case
$178 - Silverstone RV02B-EW ATX case
$190 - Corsair Obsidian Series 650D ATX Case
mATX motherboard
$59.99 - MSI H61M-P21 (B3) LGA 1155
As for case choices, I'll have to do some research to see which mATX cases are recommended. Haven't really had time to do that.
