So I just went SLI with 2 GTX 460's on a p5n-d. There is a single slot between the two video ports and its just not enough space for the heat to escape so in FUrMaRk I get 100+ temps on the top card and 90+ temps on the bottom card.
Water cooling would be best but I'd have to get a whole system and its expensive.
So what I am looking for is a heatsink that will work in a tight fit. I thought I saw one that wrapped around the card so the sink was above the card but I can't seem to find it.
The best I could find was this
ZEROtherm COOLMAXX 4000
and it seems it would work good in a tight squeeze because the fans are below the heatsink pushing air out instead of trying to suck it in which it can't because of the tightness.
Any better idea's for cooling this?
Example of the tight fit same MB but not my setup.
