robman_rob
- Mar 7, 2006
What I want it to do:
1. Play the latest games.
2. Be highly stable.
3. Able to heavily multi-task.
4. Run exponential time algorithms for problem solving (work related).
5. Basically a do it all machine.
Problem:
I want to build it myself. But I have never buit a computer before. So I came here to ask for help and advice.
Price range:
Around 1750 US, 2000 Canadian, without tax.
Stuff I want:
1. dual core AMD processor
2. BFG nVidia 7800 GT 256mb video card
3. 2 gb ram
4. fast hard drive
5. Nice monitor 19 inch +
Some questions to get the discussion started:
CPU:
1. AMD Athlon X2 or Opteron X2, which one is better suited for my needs.
2. What is the difference between them.
Video card:
Basically I am going to get a BFG nVidia 7800 GT 256mb video card unless someone convinces me otherwise.
Hard Drive:
What is faster, SATA-150 10k RPM Hard drives or Sata2-300 7200 RPM hard drives?
Sound card:
Is onboard sound good enough? If I get onboard sound, can I still upgrade to a real sound card later?
Case:
How do you pick a good case?
Here is some components I have looked up. Feel free to critize my choices, but if you do please offer explainations and other possible choices to replace it. Keep in mind what I am looking for in this system given my constraints.
COMPONENTS:
The following items will have this format:
Item
Cost (all prices in canadian dollars)
Place that sells it. (guessimation means I haven't found specifics yet and roughly estimated the cost of that component)
Comments if any.
Case
$150
guesstimation
AMD Athlon 64 X2 4400+ 2.2GHz Dual Core Socket 939 1MB L2 Cache
$534.99
pccanada
AMD Athlon 64 X2 4200+ 2.2GHz Dual Core Socket 939 512K L2 Cache
$425
canada computers
-I haven't decided which one yet, how does cache size affect CPU performance?
160GB Western Digital® Cavier SE SATAII-300 7200RPM 8Mb OEM
$94.99
pccanada
Corsair 2Gb XMS3200 TwinX Matched Pair Series (TWINX2048-3200)
$259.99
pc canada
Asus® A8N-SLi Deluxe, Socket 939, NVIDIA nForce®4 SLi Chipset w/ PCI Express x16 (ATX)
$189.99
pccanada
Asus A8N-SLI Socket 939 NVIDIA nForce4 SLI w/ Dual-Ch DDR400, Gb LAN, SATA 3Gb/s, NV RAID, AI 8-Ch Audio, Dual PCI-E x16
$141.99
canada computers
-There are two motherboards because I haven't decided which one yet
Dual Layer DVD±R/RW Drive
$50
guesstimation
OCZ PowerStream SLI 520W ATX 12V Power Supply
$148
canada computers
SoundBlaster® Audigy 4 SE
$54.99
pc canada
-do I really need this?
BFG GeForce 7800 GT OC 256MB GDDR3 Dual DVI-I, HDTV,VIVO SLI Ready PCI-Express x16 Graphics Card
$399
canada computers
monitor 19 inch
$400
guesstimation
keyboard + mouse
$50
guesstimation
operating system?
So to sum up, will this system be stable and compatible, able to play the latest games, and heavily multi-task?
If you know of better components for around the same price, please explain why that piece is better replace and show it to me!! Also for the pieces without speific components you can suggest one.
In addition, I can go a little over budget (like 200 or so) but only if it is a MUST.
THANKS !
Problem:
Price range:
Stuff I want:
3. 2 gb ram
4. fast hard drive
CPU:
Video card:
Hard Drive:
Sound card:
Case:
COMPONENTS:
Item
Comments if any.
Case
$150
guesstimation
$534.99
pccanada
$425
canada computers
$94.99
pccanada
$259.99
pc canada
$189.99
pccanada
$141.99
canada computers
$50
guesstimation
$148
canada computers
$54.99
pc canada
$399
canada computers
monitor 19 inch
$400
guesstimation
keyboard + mouse
$50
guesstimation
operating system?
THANKS !
