Looking to build this, need help
alkaline
This is what i want to build for my 1st SFF system. I would like some input/suggestions on this current build. this will be my 2nd build [i built one regular ATX system a couple months back]
ASPIRE X-QPACK
http://www.newegg.com/Product/Product.asp?item=N82E16811144161
LITE-ON Black ATAPI/E-IDE DVD Burner With LightScribe
http://www.newegg.com/Product/Product.asp?item=N82E16827106019
Western Digital Caviar 250GB 7200 RPM SATA
http://www.newegg.com/Product/Product.asp?item=N82E16822144701
ASUS A8N-VM CSM Socket 939 NVIDIA GeForce 6150 Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.asp?item=N82E16813131570
XFX PVT70FUNF7 Geforce 7800GTX 256MB
http://www.newegg.com/Product/Product.asp?item=N82E16814150100
OCZ ModStream 520W Power Supply
http://www.newegg.com/Product/Product.asp?item=N82E16817104155
ZALMAN CNPS7700-CU 120mm fan/heatsink
http://www.newegg.com/Product/Product.asp?item=N82E16835118115
AMD Athlon 64 X2 4800+ Toledo 1GHz HT Socket 939 Dual Core Processor
http://www.newegg.com/Product/Product.asp?item=N82E16819103544
OCZ EL Platinum Revision 2 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200)
http://www.newegg.com/Product/Product.asp?item=N82E16820146890
Total: $1,768.11
things i need: Monitor [suggestions?], sound card possibly.
I have a keyboard/mouse/speakers
If it was me I would hold off two days and then pick up the latest graphics card or the one you want at a lower price.
thats what i plan on doing. i just figured the card would be about that price =]
any ideas for a monitor? this will be used for gaming [CS:S, BF2, FEAR] and web browsing
how much do u want to spend on the monitor? also do u want crt or lcd...I just got my second 2405 and very happy with it
get a opteron 170 instead of your cpu and oc it a bit, same mhz speed and 2x the cache :D
Or a 165, to save a couple bucks. And yeah, the cache of an Opty really is 2x the X2's cache. No lie. :)
I dont want to OC this computer. I just dont really see the reason to do it, and i just dont really want to. I have a 2005fpw on my other rig, i was thinking about getting another. I actually think i will stick with the 7800gtx......the specs on the 7900 arent too different
