Looking to build a new system...
V3|!UM
I am planning on getting an AMD 64 3200(939), going to use my trusty Corsair 3200LLPT CL2 2 x 512mb. Sb audigy 2 ZS Gamer. I am not sure as to which Mobo i should go with, I want to overclock as much as possible on air, what is a good HS for AMD 64's? any and all help is appreciated
if you head over to the overclocking section... there are plenty of similar posts that will answer your question quite well.
uh, when was the last time you checked those boards? I did twice already, i don't have hours to kill reading through all the pages i got to 7 and called it quits. Anyway the socket 939 3200 is brand spanking new (sorry forgot to put that down), so this is a new topic i would say. I am looking at the abit/asus/msi offerings.... which of the 3 is king of the hill for OCing?
the reason i suggested the OC'ing forum, is because there is a "Search" function at the top that allows you to find what you are looking for.. not trying to be an ass, but thats probably why no one has answered you.
you'll still have to read up on whether it fits the MSI Platinum, but imo the Thermalright Xp-90 is king of the air cooling :)
