Ok I read the posts but I really dunno what to use based on my current setup...
Computer being kept in a cool area -bedroom- (unless I shut my door so I can enjoy the frag fest/mmorpg with ventrilo) it then gets a little warm in here but never over 80 degrees in the room.
Reason for wanting water cooled:
much more quiter computer so I can sleep while computer is on!
lower temps when in heavily populated area on max detail games that has been noted by other users causing their computers to over-heat
keep from loosing hearing while headset is off... roaring can damage your ear drums over long periods of extended use every day or every other day...(just like a factory)
here is entirely what I have:
Power Supply:
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
Processor:
Intel Core i7-920 Bloomfield 2.66GHz LGA 1366 130W Quad-Core Processor BX80601920
Memory:
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model F3-12800CL9T-6GBNQ
Hard Drive:
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Video Card:
BFG Tech BFGEGTX260MC896OCXBE GeForce GTX 260 Core 216 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
Operating System:
Windows 7 Ultimate 64-bit
Motherboard:
ASUS P6T LGA 1366 Intel X58 ATX Intel Motherboard
Computer Case:
COOLER MASTER RC-690-KKN1-GP Black
Heatsink:
XIGMATEK Intel Core i7 compatible Dark Knight-S1283V REV.W with ACK-I5361 120mm Long Life Bearing CPU Cooler
Fans:
Two(2)
Scythe DFS123812-3000 "ULTRA KAZE" 120 x 38 mm Case Fan
Current Thermal Paste:
Arctic Silver 5 Thermal Compound - OEM
Current temps under load:
45 degrees celcius(last I checked)
Current temps without load:
38 degrees celcius(last I checked)
Where Did I obtain parts:
Newegg of course!
Note:
I'm a gamer and do a lot of gaming - please keep it in mind.
Also, cheaper the better but please don't sacrifice quality.
Power Supply:
Processor:
Memory:
Hard Drive:
Video Card:
Operating System:
Motherboard:
Computer Case:
Heatsink:
Fans:
Two(2)
Newegg of course!
Note:
