So my federal tax refund just came in, and now I want to upgrade the power supplies for two systems in my apartment. Both are regular ATX cases/boards but one is a Win7 desktop and the other is an Ubuntu server. Both of them run 24/7 which results in my monthly electricity bill coming to $140/mo, my goal being to lower it by getting better power supplies (80+ GOLD or higher).
Here are the specs for the two systems:
Desktop:
Thermaltake Toughpower 700W PSU
Case has 3x 80mm blue LED fans, 1x 120mm blue LED fan, various blue LED lighting on the front, analog temp meter on the front, all which use molex
Asus A8N32-SLI Deluxe (one molex connector on board)
AMD Athlon 64 FX-60 (Socket-939)
4x 1GB RAM
blue LED CPU Fan
2x 150GB Velociraptors (10000 rpm, SATA power connectors)
BFG Tech GeForce 8800 GTX OC 768MB (2x 6-pin pci-e power connectors)
Creative Sound Blaster Audigy 2 ZS
PCI-to-4x SATA card (JBOD only)
Server:
PC Power & Cooling Turbo-Cool 510W PSU
5x 80mm non-LED fans
Asus A8N-SLI Deluxe (one molex connector on board)
AMD Athlon 64 4000+
4x 512MB RAM
1x 80GB IDE WD drive
1x 320GB IDE WD drive
3x 1TB SATA WD drives (7200 rpm)
4x 3TB SATA Hitachi drives (7200 rpm)
Very old fanless graphics card (geforce 4 I think? Uses AGP)
Areca 1280ML 24-port SATA RAID Controller
I've got a Kill-a-watt meter on the wall outlet for my server + "green" d-link 5-port switch, and it appears to idle at 200W.
Could someone recommend how many watts I should look for when getting power supplies for these systems? I don't plan on upgrading the desktop at all but I may add a few more 3TB Hitachi drives to the server. Is there a good online PSU wattage calculator I could use?
Also, what brands should I look for? I hear Corsair is nice because they give you free cables if you email them. Good ratings on Newegg too. What about 80+ PLATINUM? Is this the only one http://www.newegg.com/Product/Product.aspx?Item=N82E16817121080? Is it good (why is it cheaper than Corsair)? I noticed that not all the cables are modular, and I wouldn't use any of the PCI-E cables if I got it for my server (possibly a dealbreaker).
I've also got a Sun Ultra 80 + 12-drive A1000 which works great as a space heater in the winter (could turn off the heat and my apartment would still get warmer
) but I don't plan on turning it on in the summer.
Desktop:
4x 1GB RAM
blue LED CPU Fan
Server:
AMD Athlon 64 4000+
4x 512MB RAM
