Hi all,
I'm currently running two Western Digital Caviar Blue WD6400AAKS 640GB, based on the reviews I found here probably over a year ago. I am also running an Intel X25-M G2R5 160GB for my system drive. I would like to expand to 2x2TB drives, because I'm running out of space on my two 640's. My concern is that after reading some of the posts on here, there seems to be some models of questionable reliability and I just wanted to get some clear recommendations.
I care about:
Noise (I have a very quiet system and like it that way)
Performance (At least to be able to stream a movie from the drive smoothly)
Size (I would really like 2x2TB, or 2x1.5TB if there is a good reason)
Reliability (Based on the recommendations here, the drives I currently have are flawless)
Heat (To a much lesser degree, but I have a Lian Li A05B, so heat could be a concern)
I don't care about:
Power consumption
Raid
Thanks for your time!
I care about:
I don't care about:
Power consumption
Raid
