Looking for some case reccomendations
Gorilla
So my Xigmatek Elysium has served me well over the years, but the main reason that I bought it was because of how big it is; however, now I am looking to go a bit smaller. Lugging my Elysium to LANs is getting a little old.
Basically I'm looking for something more in the cube shape with levels, space on the bottom for a PSU, pump/res, and SSDs. Next level would hold motherboard, then the next level would have space for radiators. Micro ATX motherboard is fine.
The CaseLabs Bullet line looked great until I noticed that it is not meant for water cooling as the fan spaces are too short to accommodate a radiator. The Bullet line of cases gives a pretty good idea of what I am looking for though.
I would want space for at least 2x 2x120mm radiators. Single loop, just cpu and a single gpu.
Anyway, I haven't paid any attention to what's on the market for the last five years or so. Let me know what's out there.
The compartments are side-by-side and not over-under, but the Node 804 is a cube style with a huge amount of expansion options and cooling support. It'll let you do up to a 240mm radiator in the front, 280mm in top, 120mm in the rear, 12 drives and PSU in the left compartment, and mATX board with 2 full length GPUs in the right. It's certainly worth a look in my opinion.
Node 804
If you're looking for something to take to LANs, is watercooling really the way to do it? Air cooling is going to let you drop a lot of weight and size.
