MeatballCB
- Oct 8, 2008
Alright, I've been banging my head against the wall on this issue for the last week or so and can't for the life of me figure out what the issue is. About a month ago I decided to upgrade my aging i7-860 system and move up to something newer, so I built a new machine with the following specs.
Everything had the lastest drivers/patches/bios/firmware and nothing was overclocked. I started noticing that occasionally on reboots the post/boot process would hang with an error code of "9C" in the bottom right hand corner of the screen. I contacted Biostar and after going back and forth with them a bit, they thought it might have been a Mobo issue and offered me an RMA. So, in the meantime, I tried another board and swapped the memory.
This time I saw the same thing, but was getting the error code "CA" in the bottom right hand corner. I was able to pin down that this was only happening when I would boot into windows, log in, and then do a restart. If I did that, 75% of the time, the post would hang with the error message. I ran Memtest86+ for over 12 hours and found no memory issues. Talking to MSI, they believed it was either a CPU or Motherboard issue. I returned the motherboard and moved onto round 3 and swapped out just about everything.
The only thing I have not changed is the PSU, the case and the 2 DVI connected ASUS LCD's. I disconnected all my USB peripherals except for a mouse/keyboard. Once again, if I logged into Windows and did a restart, most of the time the post would stop, this time with a "99" error code. At this point I'm at a loss as to what could be causing it. I'm going to try swapping out the PSU next, but I'm wondering if this is just some sort of bug in Windows 8 Pro x64. If that doesn't work, I'm probably going to drop back to Windows 7 and see if I get the same problem.
Has anyone seen anything like this or does anyone have any idea what could be causing these issues?
- Mobo: Biostar TZ77XE3
- CPU: Intel i5-3570K
- Cooler: Cooler Master Hyper 212 Plus
- Memory: 16 GB (4 x 4 GB) G.SKILL Ripjaws, 4 x 4GB DDR3 1333 (F3-10666CL9D-8GBRL)
- HD-OS: 256 GB Samsung 830 (MZ-7PC256B/WW)
- HD-Storage: 1 TB Seagate Barracuda (ST31000528AS)
- DVD/CD: LG GH22NS70 DVD-RW
- GPU: Sapphire Radeon HD 7970 OC 3 GB
- PSU: Corsair HX850
- Case: Rosewill Thor v2
- OS: Windows 8 Pro x64
- Mobo 2: MSI Z77A-GD55
- Memory 2: 32 GB (4 x 8 GB) G.SKill Ripjaws X Series DDR3 1600 (F3-12800CL10D-16GBXL)
- Mobo 3: ASRock Z77 Extreme 4
- CPU 2: Intel i7-3770K
- Memory 2: 4 GB (2 x 2 GB) G.Skill DDR31333 (F3-10666CL8D-4GBHK)
- HD-OS 2: 60 GB OCZ Agility 3 SSD (AGT3-25SAT3-60G)
- HD-Storage 2: 2 TB Western Digital WD20EARX
- CD/DVD 2: LiteOn iHas124
- GPU 2: MSI Geforce GTX 670 2 GB (N670GTX-PM2D2GD5/OC)
