Ok guys, I've read the sticky about OC'ing and read the related thread about RAM OC'ing, so I'm feeling fairly confident about attempting to overclock my system... But since I'm the kind of guy that would rather be safe than sorry, I wanted to get your opinions/suggestions before I start.
Here is what I'm working with:
AMD 3500+ (939)
Asus A8V Rev. 1
1GB Corsair CMX-3200XL RAM @ 2-2-2-5
I've already went into bios and looked around, and enabled everything to manual. I changed the FSB to 210 to try things out, with success. However, as I rebooted to attempt a higher FSB, I got the blue screen saying I had a BAD_POOL_*** something, which turned out to be a bad registry file that Windows repaired.
To cut to the chase, I was hoping you guys could give me some conservative figures to aim for tonight, as far as speeds, fsb setting, and the ram settings. Also, I wasn't able to see anywhere to setup FSB:RAM ratios such as 5:4 in my bios... The ones I remember it listing were 1:1 200mhz (DDR200), 5:3 166 (DDR333), and 2:1 200 (DDR400) <-- which I set it on.
I'm using a Thermaltake Silenttower as my hsf (yea i know
) and I idle 34C & hit 44C at load.
Thanks for your help!
**P.S. Hope to hear from you cornelious0_0!**
AMD 3500+ (939)
Asus A8V Rev. 1
