Looking for socket 1155 CPU cooler recommendations
rayz
New build. Going to be running the i5-2500K.
No water, air only please.
Thank you!
Price wise? $50-$80.
Best bang for the $ I suppose.
Will a socket 1156 cooler fit a socket 1155?
i have two hyper 212+ coolers on on a i5-750 and the other on my i5-2500k (@ 4.3Ghz) they are cheap as **** (i got my 212+ coolers at fry's for $20ea) they work good. If I'm honest the stock fans are not bad..but they are a bit louder than I like I swapped the fans for gelid silent 12 fans for $10 ea so for $30 i have a near silent excellent performance cooling solution.
there is a new 212 evo that might be worth looking at..
http://www.hitechlegion.com/reviews/cooling/heatsinksfans/13336-cm-hyper-212-evo-cpu-cooler-review
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
