Ingonuts13 said:Again, I would check out Geovision. How many cameras do you want to do?
-4 with the ability to upgrade. I was thinking a PCI DVR card to support 4 cameras and if I ever want more I can add another PCI card.
What are the exact specs of the PC you are going to use for this system?
-Depends on the demand of the equipment I get and the software. I was thinking an Athlon 64 or Intel Dual Core with 1-4gigs of ram and at least 250gb of storage.
Nightvision has to do with the cameras and the IR capability.
-this is a must for my cameras
What state do you live in, as I can probably reccomend one of my customers to you since I have them all over.
-Upstate, NY. The real upstate, not Westcheter county or just north of NYC that some people consider upstate.
If you are looking to do linux there are not that many options out there right now compared to Windows based.
-I only wanted linux because I want this to be a low cost build and don't want to spend money on windows
enyceexdanny said:Give posmatic a call.
They do alot of camera installations as well as custom developed software.
www.posmatic.com
Ingonuts13 said:As far as the PC goes you should stick with this.
Intel Only with 865 or 915PL chipset. No DDR2, no Dual core.
