obsidian_mh
- May 26, 2005
I'm looking at putting together a RAID5 solution for my own use over the summer. I haven't decided on the final amount of drives I want to use yet, but I imagine 4-5. The system will be running either Gentoo or Ubuntu, depending on how lazy I am.
I'm looking for a dedicated PCI-Express card to control these drives, as I'd prefer not to rely on Linux RAID. So the card will need to be Linux compatible and be able to support 4-8 drives.
I was looking at the DELL PERC 5/i's, which aren't bad for $115-150 on eBay. The only problem I can see is the motherboard compatibility and PCI-Express x4 or x8 slot. The machine I'll be installing the array on will have an available x16 slot, so I imagine I'll be able to use the card in that?
The reason I'm looking at the PERC 5/i's is because I was considering two separate arrays, 4 SATA/II drives in RAID5 for storage, and 4 SAS Drives in RAID5 for the system. The SAS is question, but the PERC card seemed pretty good for the price.
What are my other options?
