Looking for rubber safety edging
Mark2000
I'm looking for something I can line the sharp edges of my case with. Like some kind of clear or black u-shaped, rubber moulding. I've tried every kind of syntax I can imagine in google and I've come up empty. If someone could at least give me the exact term for this material i would be really grateful. Thanks!
Those are called door molding I think. I know for a fact that you can get them at auto stores like AutoZone or Advance Auto Parts.
Yeah, they have some good stuff at car parts stores. It's made to line the edge of your door so that it protects the other car if you open the door into it.
Lowes/HomeDepot in the window/door section. Autozone/AdvancedAuto/NAPA in the weatherstripping section.
You guy are a help and a half. Thanks. I found the perfect stuff at mcmaster, real cheap.
