Looking for replacement board P-4/ 2.53
AP514
Well, I want a replacement board for my P4 2.53 any suggestions ???
Note the reason Im looking is my Abit BD7-II is geting way to hot.....I got it in a new Case. I added some Case fans to help with cooling after I looked and saw my MB and CPU temps in the mid to upper 50's...I never really looked at the temps before but Just built a new rig and it runs 44 C at max load. I have 2-80mm in (front) and 1-80mm (side) 2-80mm exhaust (back) plus my Cheap PSU fan.
Any help would be great.
AP514
BUMP
Anyone have a good MB suggestion for my old P-4 2.53mhz ??
Unless you fork over your budget and goals of the upgrade, some peeps will not step up.
How much $ do you have for the upgrade?
Do you want an intel board?
Are you looking to improve gaming performance?
I recommend an AMD board, I am sure you know why.
Well, I guess I would have to say is READ the post before maken a suggestion like that.
Unless im mistaken I have never heard of AMD motherboards for an INTEL P-4 2.53 CPU :D
as far as price I figure a few buck on E-bay or some place that still sells old boards that have the 845 chip set in them. I was looking at an Asus P4GE-V if I cold find one.
But im open to any suggestion...............
AP514
well i would suggest something like an Asus P4P800 SE as you would get dual channel ddr400 support as well as 800mhz fsb support and maybe try to overclock your 2.53 to somehting higher.
I believe the board costs around $130cdn so in USD it should be under $100
