Ok, here's my situation. I have 2 LCD monitors that don't match. (bought one when the other was in for repair)
One is a crappy Envision 22" and the other is a slightly better Hannspree HF259 (25" 1920x1080).
The Envision has the standard 4 hole mount holes on the back, however the Hannspree has a 6 hole mount on the back. Basically looks the back look like the 4 hole mount, plus 2 evenly spaced off on the horizontal plane.
Sooo, does anyone know if there is an LCD dual arm mount that supports the 6 holes? If not, can I get away with just mounting it with the 4 holes?
I'd say my envision ways about 7-8 lbs, and my Hannspree weighs about 16-17 lbs with stand attached.
