Blindbatts
- Feb 18, 2006
also needs to be as low as possible.
I have tried 2 things so far, one the coolermaster cooler that came with the cpu - it's horribly loud, when I unplug it the system sounds silent it makes such a racket.
my girlfriends desktop runs a socket A with the same coolermaster hsf but I removed the fan and used a 60mm -> 80mm adapter to use a standard 80mm fan that runs much quieter, unfortunately this is too large to fit inside of the Qpack case.
any pointers to what I need to buy?
I'm not overclocking, nor will it ever be. 1.33ghz amd thunderbird socket 462 / A I believe.
