Abula
- Oct 29, 2004
I have a bunch of pc components that are left over builds that i want to put in use in HTPC,
CPU: Intel Core i3-2120
CPU Cooler: Scythe Mugen 3
MOBO: Intel DQ67SWB3
GPU: Sparkle GeForce GTS 450
HDD: Crucial M4 64GB
Memory: G.SKILL ECO Series 4GB
Fans: Scythe Kama FLEX PWM 120 SA1225FDB12H-P (have 8 that i didnt use on the server build).
On the PSU im stil deciding between Seasonic X-560 or Seasonic X-400, probably dont need the 560W but both are at the same price.
I game a lot but on my desktop, i dont plan to play on the HTPC but on a rare ocasion with friends over i might. This HTPC is going to be mostly used for 1080p playback, probably madVR.
Now where i need opinions is the case, the problem is that i want to use Mugen 3 and the Sparkle GPU, but with both i think it rules out most of the HTPC horizontal cases, although im open for one if you know it will fit a 158mm height cooler. I dont mind it to be a vertical tower so im looking into those atm, i would like it to be as quiet as possible, this is what im looking atm but im open for suggestion,
Antec Mini P180 Case
Like a lot the looks specially black interior, its micro atx but seems big, i would dump both hdds cages for dual frontal fans (spinning at 300rpm), seems wide enough to fit the mugen 3 and has sound dampening on the side panels, easy to access fan filters. Worried a little about the top 200mm fan if its going to be quiet or noticeable on low.
Antec Sonata Series SOLO II
Wasn't planning on considering ATX cases, but seems this case is materialistic and with dual fan on front, seems to have good cooling and very low obstruction for the fans, like the looks although not a big fan of glossy finishes. The fan filters seems semi easy to access as you need to take out the side panel to push the ledges, but after that seems very easy to remove. Not a big fan of top PSU mounted cases, but seems it helps to keep the gpus cool with fans oriented there. Don't like the lack of CM holes, but i guess its not that bad either.
SilverStone FT03B
Micro ATX, like the design, but not sure if it would be a quiet case, i might not be able to use the intake cpu case fan cause of the orientation and the mugen3. Like a lot its a mate finish and the cables stay fully hidden with the design of the PSU. Not sure how would compare on cooling with the other two.
Thanks for taking the time on reading, looking forward to your opinions and im open for other case suggestion.
SilverStone FT03B
