Looking for multiple systems in one case setups.
ADDICT76
I'm looking for those who have used large cases and have 2 systems running in one case. I've seen it done in the past and always thought it was wild. I'm sure with the massive amount of modding talent here, someone has done it.
EDIT: Hmm, didn't really read the text and I can't find any Delete Post button.
well, theres always just doing a dual motherboard slide ut tray, i have seen that done, with a server mobo on one side, and a workstation mobo on the other, watercooled (both systems on seperate loops) and all this in a fully pimped case (on another forum though...) i will have a look around for it...
are you looking at multiple full size ATX (or EATX), or just a ITX or mini ITX system for running torrents and/or playing music?
the Thermaltake Mozart case has enough room for an ATX system as well as an ITX system on the other side of the case (and enough room for like 5 WC loops lolz...)
EDIT: here you go:
http://coolercasesuk.co.uk/showthread.php?t=3229
It is an absolutely awesome mod, and he does all kinds of insane things like that, have a look, cos there is some insane shit around...
Thanks Guys, yeah I'm looking for dual ATX support.
Just thought it would be sick to have my media server and my gaming rig in one box.
This is the sexiest case i have seen in a while.
