[LYL]Homer
- Jun 7, 2004
I need to build 2 systems for the office and order parts in the next couple of days. Some basics:
Dual-core cpu if I go Intel with these, probably 930 for decent cooling.
No overclocking, just office PC
Used for 2D Autocad, would like Intel onboard equivalent of nForce 6150 graphics (initial monitor will be 19" CRT @ 1280x1024, then upgrading to 24" Dell LCD @ 1920x1200, 6150 graphics work fine for this)
DVI out (do any Intel boards do this?)
Gigabit LAN
Stock Intel cooler? Zalman CNPS7000B-ALCU?
mATX format (to go in a Coolermaster Centurion 541)
Basically in competition with the following cpu/mobo/hsf:
MSI K8NGM2-FID
CNPS7000B-ALCU
Athlon64 3700+ (2.2ghz, 1mb cache, single core)
$294
or
MSI K8NGM2-FID
CNPS7000B-ALCU
Opteron 165 (1.8ghz, 2x1mb cache, dual core, might put a mild ~500mhz o/c on this one)
$384
Trying to get most bang for the buck, but I'm kind of hung up with the Intel mobo on whether I can match the 6150 DVI graphics onboard, or have to buy a video card to match the AMD systems. By my calcs with a video card the Intel system could be in the $350-380 range, and I'd probably go for the Opteron 165 system.
Gigabit LAN
MSI K8NGM2-FID
CNPS7000B-ALCU
$294
or
MSI K8NGM2-FID
CNPS7000B-ALCU
$384
