Looking for ideas.
Liver
I used to have Starlink for a couple of years. We got fiber and I gave the dish and router to a family member. I kept the usb c cable because it was already imbedded in the house.
The cable runs from my media room to the top of my chimney. Removing the cable is way more hassle, and there is no problem leaving it up there.
However, what else can I put up there using that USB C cable? Anything worthwhile? It’s at the highest point of our property (highest point of the land, and then it’s on the chimney).
I have a full (no other brands) Ubiquiti intranet and camera set up.
I already have a Tempest for weather monitoring, and that is using the Starlink bracket that I did not want to remove.
Suggestions?
forget about it. maybe cap it so it doesnt rust out, in case you ever come up with something to put up there.
It’s capped and sealed. I got no ideas what to do with it. In the conduit I have cell antennas, TV antennas (not being used), driveway proximity alarm antenna. And this cable.
Edit. If I could use this cable as a replacement for a 4x4 mimo 5G cable, I’d remove everything in that conduit.
Arduino or microcontroller on the top of your chimney doing whatever you want. Homegrown weather station, cameras, laser turret, whatever you may need.
