Looking for Help on First Liquid Cooling Build
Drock37
Hello All,
(Ill start off by apologizing for the long post. I am trying to be detailed to get the best answers possible. I will include a tl;dr at the end to sum it all up)
As of lately, I have been getting back into computer building, and have decided to build my first 'Enthusiast' gaming rig. I have never had a real serious computer, nor have I ever tried out liquid cooling (other then the closed loop CPU ones) so I decided I would go somewhat 'all out' on this one. It's been smooth sailing as of now as I'd say I'm more familiar with computers and building them then the average guy, but my knowledge of liquid cooling is minimal at best. I have gotten most of my components so far, but I still am looking to upgrade a few of my items from my last build. Here is what i am working with so far:
CPU: Intel i7-4770k Haswell
Motherboard: Asus Maximus VI Hero
Video Cards: Dual EVGA GTX 670 FTW+ 4GB in SLI
RAM: G.Skill Ripjaws 16GB 1600 (Looking to upgrade to 16-32gb of 1866-2400)
Os SSD: Kingston HyperX 3k 120GB
Storage HHD: Seagate Barracuda 2TB
PSU: Kingwin Lazer 1000W Modular Looking to upgrade to: Corsair AX1200 1200W
Case: Corsair Obsidian Series 900D
Monitors: Triple Samsung 23" LED BX2331
Os: Windows 7 Ultimate 64 bit
While there are obviously higher end items out there, like the Titan, or the i7 extreme models, I think I picked up some pretty high end items. My goal was to get the best products I could without breaking the bank/having my girlfriend dump me haha. I think the case is the biggest case I've ever seen; but I love the way it looks, and it fills the space I am putting it in beautifully.
Now that you can get a picture of what I'm working with, onto the reason I'm posting here in the first place: Liquid cooling. I don't really have a budget in mind, but i figured i would try to spend less then or around $1000. Obviously this number can increase or decrease depending on your answers here. I am the kind of person that I would rather spend more on quality products then have to replace a lesser quality item in the future. I also like the ability to grow with items, so I would rather get a pump that can handle a longer loop if I decide to liquid cool other items on my rig, etc etc.
From the research i have done so far, I have decided to go with EK products for their overall performance and looks, but i am open to other suggestions. Here is what I have set up so far. Currently I only plan on Cooling my CPU and the two video cards, I might cool my RAM / Motherboard / Hard drives down the road if i find the need to, or just get bored.
Pump/Reservoir: EK D5 X-Res w/ D5 Vario Pump
CPU Block: EK Supremacy
VGA Blocks: EK GeForce 670 GTX VGA Block
VGA Backplates: EK GeForce 670 GTX VGA Backplate
Top Radiator: EK CoolStream 360 XT
Bottom Radiator: EK CoolStream 480 XT
Radiator Fans: Corsair SP120 Performance Edition
Case Fans: Corsair AF120 Performance Edition
Fittings: 3/8 x 5/8 Compression Fitting (I haven't decided on silver or black yet)
Tubing: PrimoChill PrimoFlex 3/8 x 5/8 Clear
Here are my questions so far:
1) I know nothing on pumps. Will this one be ok for what im doing?
2) Do i need to look into a pump controller? Or will simply plugging it into my PSU be enough. I'd be interested in getting an Lamptron or an AquaComputer or something if it would help.
3) For my loop I plan on going from my Res/Pump -> CPU -> 360 Rad -> VGAs -> 480 Rad -> back to Res/pump. Is this the best loop or should I try to incorporate going from a Rad before a component? I'm trying to have the shortest connections possible.
4) As you can see from my list above, I have not chosen a liquid yet. What liquid are you guys using now? I see so many out there with anti algae and anti corrosive additives in it. I also have seen some non conductive stuff, which to me seems the best.
5) My 670's already come with EVGA backplates on them because they are the FTW editions, am I able to use these? Or do i need to purchase the EK ones listed above.
6) I haven't chosen anything for my 'Sli Bridge' to connect the two cards. Should I just go straight tubing? Or is the block method better?
7) Any suggestions on Ram? I don't know enough about timings and such to really pick something out definitively.
8) Am I missing anything? I have tried to do as much research as I can, but being that I have never liquid cooled before, I would love some advice/help from some of you who have.
TL;DR : I am building my first liquid cooling rig and while I have a good amount of it built and ready to go, I still have a few questions on the liquid cooling side and am looking for some help/advice and some suggestions on different components.
Any and all help will be greatly appreciated.
The D5 with a pump top will handle your needs. In the case of Rads, I would go with Alphacool UT-60's over the EK's in a heartbeat. Aqua makes great gear all around and the Aquaero is the cats pajamas.You might also check out their Kryos CPU H20 block.
It's best to use distilled H20 and a biocide and stay away from most coolant fluids.
HTH
