Working on my first water cooling build and looking for a critique on my parts or helpful suggestions. My goal is quiet operation, decent cooling performance and some overclocking potential. My case is the Corsair 500r. I plan on upper and front mounting the radiators in a single loop. They'll fit with a little work and a size less than 36mm.
I know for sure I'll have:
crossfire 5870's
Can figure a 2500k range CPU/mobo combo
2x hdd's
5x 120mm fans and will probably remove the big side fan.
I have a Seasonic x750 gold but don't believe it will be powerful enough for everything
My cooling list...
2 - 240mm radiator, looking at xspc ex240, black ice stealth gt, or Swiftech QP. The black ice is the thinnest but I think will require more of a high speed fan setup.
xspc razor's on the 5870
xspc raystorm
I need some suggestions for compression fittings, fans, and a res/pump setup. I was leaning toward the Swiftech MCP655 and a Aquacomputer aqua tube res. Small and easy to mount toward the top.
crossfire 5870's
2x hdd's
My cooling list...
xspc raystorm
