Looking for help color matching two CRT's
DrCreep
Hi all,
I'm in a bit of a fix, and I'm hoping that I could get some advice here.
I've been using an NEC FE950+ for quite a few years, and have just got a hand-me-down of the same model from my dad (his was purchased from the same place, two weeks after mine). Having not made the jump to LCD, I figured I could at least run dual monitors in the meantime.
The color on my original has always been very nice once tweaked. I've never used much more than the nvidia display optimization wizard with a few settings of my own.
Now that I have two of these monitors running side by side, I'm noticing quite a difference in color, and I'm having some troubles getting them to match up. If I span a window across both displays, there is a noticeable change in colors. I've ran the nvidia wizard again with both monitors, and if anything, I've made things worse... the colors are even further off.
The second display seems to have a higher level of red, but as I take the red down in the monitor's on-board control, it seems to drive other colors out as well.
I'm pretty new at this, but am capable of learning. Can anyone recommend a method I can use to match the color up on these two monitors? I'm sure it's an in depth and time consuming process, but consistency is worth it to me.
Thanks for all the help.
Doc
Hi all,
Doc
technicaly teh gain needs to be adjusted on one of the monitors but i wouldn't worry with that. did you try switching the monitrs on the output of the video card to see if it is the monitor are the card see if it follows (long shot i know ) ?
Good call. I did try this though. The short of it is, it is indeed the second monitor that's running heavy on the red.
mlewis said:
Hardware calibration kit such as X-rites I1 Display 2.
Thanks for the recommendation on this. I'm hoping I can fix this somehow manually (and without spending a bunch of money), but if it comes to it, I may look into something like this.
I tried playing with the color settings in the nvidia control panel again last night. I was able to at least make things look decent, but it's still leaving much to be desired. The gamma controls were handy, and helped quite a bit. I wasn't able to do much with the color though. I could reduce the red until it looked normal, but other colors looked too far off. I also tried adjusting all colors a little at a time, but didn't have much success. I'll keep doing more reading on this to see if I can learn some more. In the meantime, I'd certainly welcome any suggestions or advice from experience.
Thanks
Doc
I wouldn't use the color settings done via the GPU. Better to use the built in color adjustment menu of the monitor. Set your father's color temp to the same as your monitor, and then tweak it from there. Considering you're saying your father's is too red, i'm going to guess that your monitor is set ~9300K and your father's was set ~6500K.
Here's a link to the User Manual.
http://safemanuals.com/user-guide-instructions-owner-manual/NEC/FE950
