Looking for good looking case that isnt MASSIVE with ....
Macca
Hey,
Looking for good looking case that isnt MASSIVE with maybe 3-5 case fans and has USB ports on the front...
Or just some ideas for using with
( possibly 1 of these 3:
ASUS A8V
MSI K8N NEO2 Platinum Nforce3
Abit AV8).
Thanks, Macca.
hehe I am sure you are going to be told that using the search function will answer your questions... :D ..but in my case, I kinda like the Kingwin cases
http://www.xoxide.com./kiktb.html
But the final choice is yours, go with something you like, and not what others like.....it is always the best choice. What's your budget limit?? that can really decide on what u can or can't buy
Hope this helps :D
I really <3 my Lian-Li I got from these guys. It is on the big side though. If you want something a little smaller/cheaper, I like the Enermax lineup, but make sure you get one with an Enermax PSU vs the PowerUp ones.
/me wuvs his Tsunami, 3 fans, rooms for lots of drives, top mount USB, Firewire and Sound (if you can figure out the wiring ;) )
