Working on building my first machine that has a custom water cooling loop in it. Would like to have someone check over my setup to make sure things are correct plus I have three questions.
Questions
Parts:
Video that got me interested in doing this build although it is for the ATX version.
Link
Layout (Note: I am using flexible tubing not hard tubing just hard to model flexible in SketchUp)
Front
Questions
- Drain Valve - I believe I want to put this on the back at the bottom where I passing through the chassis. How should I set this up though? I am thinking of either using those Koolance Quick Disconnects or using a Drain Valve. Not sure which way is best or if there is a better solution. I have 38mm of clearance in the back so should have plenty of room to put whatever I need back there to do the drain.
- In the future once I get the CPU loop all working I will want to add my GPU to the loop. Is a the single 360 radiator enough?
- I haven't seen the Hardware Labs Black Ice Nemesis L-Series 360 Stealth Radiator radiator reviewed does anyone have any experience with it? Other rads from that vendor seem to get high marks.
Parts:
- Case - Lian Li PC-O6SX
- Motherboard - ASUS Maximus VIII Gene (mATX)
- CPU - 6700k
- GPU - 980 Ti (Reference)
- PSU - Seasonic 750 KM3
- Radiator - Hardware Labs Black Ice Nemesis L-Series 360 Stealth Radiator
- Pump/Reservoir Combo - EK-XRES 100 Revo D5 PWM
- CPU Block - EK-Supremacy EVO CPU Water Block
Link
Front
