Looking for Fan (blower), ITX size.
nekrosoft13
Ok, i'm looking for small fan (blower) for ITX system. it used was used as CPU cooler attached to aluminum heatsink.
original works for 2-6 seconds and shuts off, causing the system to overheat.
Original was made by Y.S. Tech, DC12v 0.10A DC Brushless Blower. about 50mm by 50mm and about 7-10mm (don't have accurate measure)
all side are closed, except one on the side opposite from the fan header the side is open. it blows hot air outside.
Help me find a replacement.
is it just a basic cpu sink like this?
just pick up any 50-60mm fan, higher airflow/less noise
I found the blower on the companies site. They have a sales page maybe you can contact someone on that page to get one.
try digikey.com. Search "blower fan" apply filters to find your match. they are not cheap tho if you do not buy in bulk.otherwise, you can look out for notebook fan replacement modules on ebay etc.They are usually blower style (sucking in air from beneath and blowing air out the one side) These are usually pulled from non working laptops but it does not mean they are cheaper.
