Looking for Cheaps Laptops
Red Dawn
C2D's and first and second gen ICores etc. WIth or without Hard Drives. Will consider Laptops with brokens screens, keyboards etc if price is right.
Please PM me what you have to offer and your asking price
I have a couple laptops I'd like to get rid of!
i3 first gen 2.4Ghz, 4gb ram, dedicated video card, no HDD. 14" screen
core 2 duo era c700 compaq presario, screen appears to be broken, no HDD. 1.5gb ram? I believe its a 15" screen
250$ shipped for both!
I have the following:
Dell D520
C2D T5500
15" LCD
2gb DDR2
320gb 5400rpm Hitachi drive
Power Adapter
Battery, holds a good charge
Windows Vista installed (I can include a copy of the Dell Restore disc)
$100 shipped in lower 48
Toshiba P105
17" LCD (There is a vertical line on the right side, but screen is still good)
C2D T7200
500gb 7200rpm Hitachi
4gb DDR2
Vista Home Premium COA, but Vista Enterprise is preloaded and activated (I will include the COA)
There is an issue with the laptop. On AC power only the unit works great, on battery power the unit works great, but when the unit is on and and charging the unit will overheat while being used.
I am asking $100 shipped
I have an Asus (forget the model number) i3 - 4GB DDr2, 15.6" screen, full-size keyboard, Windows 7 Home license. - $200 shipped in the original box - BUT - the charger port is jacked up and needs to be replaced, it works but you have to hold the cable in with a little force in order for it to charge.
PM me if you're interested.
May be getting rid of my current laptop --
Dell 15R i5 (first gen), 2.66Ghz, 6GB ram, 64GB SSD, optical burner, battery holds about 1 hour of charge.No scratches on screen or inside. includes AC adapter. Very clean and ready to rock. Includes activated copy of Win7 on HDD. Only issue I've had is out of one of the USB ports, anything I plug into it sometimes isn't recognized (it will charge anything though) I suspect it's an issue with the Win7 driver installation, not sure. Other three USB ports work fine.
Asking 220 shipped -- i gotta get my replacement laptop first so I'm happy to keep in touch via PM or email. Heatware: collegeboy69us
I have a Lenovo T510 with 3GB RAM, first-gen Core i5, 160GB HDD (need to verify), and no OS installed. (Win 7 Pro COA included). I'll also throw in the original Lenovo AC Adapter. This system is in reasonable shape, save for one USB port which is broken. The one above it works fine. No cracks in the case or defects in the screen. The keyboard and touchpad are in good condition and work well. 9-cell battery is included but is well-used; it probably holds 1.5-2 hours worth of charge.
$150 shipped, although I may need some time to find a box.
