looking for case advice
ilkhan
* I sleep with computer on every night, the single case fan is a papst 80mm, rated at 19db. Stock P4 and the truepower are the only other fans. I can hear the fans and they BIG me. So 120mm fans are prefered, but I just got a couple really quiet 80mms. So 120s prefered but not required,
* 4 front 5.25, 2-3 front 3.5. 4+ internal 3.5. prefer 2 removable cages
* Black/Silver
* Aluminum. weight
* no need for a included PSU
* window is fine, but if not doens't matter
* front USB a big +. Front audio (mic) is good. nothing else needed.
* Budget 80-160. Less is better.
Using a 635SX now, its nice but I want to move up some. Little bit bigger would be great. No front USB is a PITA. PSU replaed with a True 330W, it will be moved to new case *its quiet*.
Also looking for a fan controller, as the fans I have for new case are LOUD. I could just 7v, but what fun is that? Needs to control 4 fans, fit a 5.25 bay. Black/siler is fine. Cheap is also a good thing.
bump. anybody got some advice?
LAN party on fri night was fun, one of the guys had a SLanboy. Looked good, but a little smaller than I was expecting.
