Looking for black mesh/filter/fabric for case front
Ej24
I have a cheapo Thermaltake case for a workstation and it has horrible airflow. I want to cut out the middle portion of the front panel leaving just the perimeter, a rectangular frame basically. Then I plan to stretch some sort of black mesh fabric over it to make it like a crappy diy Meshify C. Most mesh sold for pc's is small, expensive and fan sized, not case size. Typical fabric from sewing/crafts suppliers is too dense not like open mesh. I guess maybe fiberglass/plastic window screen material would be good? Though that mesh tends to be pretty wide, I still want some filtering of dust. Anyone have suggestions on a good, cheap material?
THUMPer
Not sure, I've never used it myself. Haha. I've special ordered a demci filter. It works real well. What case is it? Just curious.
I've also bought some filter material off of moddiy.com
Ej24
Thermaltake h17 matx case. It has some perforated metal around the edges of the front panel but it's actually closed off. I realized the metal was for looks. So I cut out some of the plastic behind the metal using a dremel and it can get a little air through that now but it's still struggling to move a huge amount of air considering it's got 2 noctua 140's up front at like 70% max rpm.
So I figure f*ck it I'll just cut out the entire middle portion of the front panel.
Ej24
Getting a new case will look better. :ROFLMAO:
OH for sure but any funds are being dedicated to some used enterprise SSD's. I figure some filter/mesh is the cheapest option. This purely needs to be utilitarian, not pretty
pendragon1
second the panty hose and you can get windows screen small enough that it will help and that ^^
luisxd
You could try get normal metal mesh at hardware stores or workshops, they usually sell it by meters but it's cheap. There are different "styles" but the most common has a 1/8" holes pattern.
pendragon1
1/8" holes are not going to filter much. it needs to be down to like 1mm or smaller for it to filter properly.
luisxd
This is what it looks like.
Ej24
Well that was the best $8 I've ever spent. Cpu temps dropped 20C. Astonishing. Doesn't look like a total dumpster fire. Doesn't look uber professional either but damn it is functional. Case fans are actually quieter now too even though they're all running at the same rpm there's much less turbulence now that the air is mostly unimpeded.
Case kind of looks like a speaker now lol.
Ej24
The ugly beast
Almost forgot about the front i/o :D also tried to singe the corners with a lighter to melt it down a bit so it's not sticking up. it's easy to melt as its polyester. But it started melting more than I wanted so I gave up on that endeavor.
Cut out enough of the front panel so basically two 140mm noctua fans are completely unobstructed. Insane airflow now.
Roughly this much is cut out
I was worried the speaker fabric would be too thick but honestly it's pretty cheap fabric so even though it's thick the density of the weave is super low so no problem at all. Basically wide open front now, but filtered.
Meant to take pictures of the "mod process" but honestly I figured you all can imagine cutting out a huge rectangle with a dremel. Stretch fabric over remaining frame and super glue the fabric around the edges. Not terribly interesting.
I was super close to just giving up on this case and getting a meshify C, but that's about $100. Yeah it's a better case but this was also just $8 to fix this one. Can't argue with just $8.
Ej24
For anyone interested I ended up using this particular fabric
I'm sure if you took your time, you could actually make it look quite good versus my utilitarian approach. It's available in several colors too so that's cool.
