Looking for ATX form factor case that's super stylish
Jason
Way back when my buddy and I built a briefcase PC. It came out alright. It was fully funciontal. It just didn't look polished off enough. So now... we want to buy a premade (or perhaps build one if it's going to be that much cheaper) case and really pimp this puppy out. Our only concerns are we want it to fit a microATX board and have room for some PCI cards. The system itself is a Athlon 1600XP. It's a fairly decennt system and will work perfectly for what we need it to do. Mostly it's going to act as our media center. We'll load all out movies onto it and stick it next to the tv. We'll also most likely hook it up to the cable box and we can set up stuff like X-Box Connect and what have you.
Long story short, we wnat something really slick looking, but not too terribly expensive.
Any sugesstions.
Lian Li or one of those Wave Master dealies...get one that matches the components your
gonna place them next to.
just micro-atx? or do you want full atx options too?
i'm really wanting an antec aria.. i think it looks really slick. micro-atx only though.
if you want a more htpc minded case look into the silverstone lascala line.
