Looking for ATi9800Pro 128 Fan replacement
kur1j
The fan went out and I need to replace it. There will be no overclocking just stock voltages stock clock stock mem stock everything.
http://www.3dnews.ru/documents/5766/ati9800pro-cooler.jpg
That is what it looks like :-/.
Not sure which fan will fit the thing (or will all the GPU coolers fit all the cards)?
I don't need anything extreme just something equivalent to the stock cooler.
The VF700 is a perfect match, the VF900 would work but IMHO it's overkill for the 9800 Pro.... though it would look badass anyway. :D
Also you might consider this SilenX cooler for just over $20, it should perform as good as the Zalman VF700 and is a bit easier on the wallet:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835226017
